Silent Fan 140mm image number 0
Silent Fan 140mm image number 1
Silent Fan 140mm image number 2
Silent Fan 140mm image number 3
Silent Fan 140mm
Silent Fan 140mm
Silent Fan 140mm
Silent Fan 140mm
Silent Fan 140mm
Silent Fan 140mm
  • Screws 4 pcs
  • Fan Power Connector 3-Pin
  • Legacy Cooling
  • Fan Life Expectancy 35,000 Hours
  • Fan Bearing Type Sleeve Bearing
  • Fan Rated Current 0.08A
  • Fan Power Consumption 0.96W
  • Fan Dimensions (L x W x H) 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • Fan Noise Level 16 dBA
  • Fan Weight 170g
  • Fan Air Pressure 0.82 mmH2O
  • Fan Speed 1000 RPM
  • Fan Airflow 60.9 CFM
  • Product Number R4-S4S-10AK-GP
  • CPU-Z - Cooler Master 32 & 64-bit versions Download
