MWE 450 Bronze - V2 230V image number 0
MWE 450 Bronze - V2 230V image number 1
MWE 450 Bronze - V2 230V image number 2
MWE 450 Bronze - V2 230V image number 3
MWE 450 Bronze - V2 230V image number 4
MWE 450 Bronze - V2 230V image number 5
MWE 450 Bronze - V2 230V image number 6
MWE 450 Bronze - V2 230V image number 7
MWE 450 Bronze - V2 230V image number 8
MWE 450 Bronze - V2 230V image number 9
80 Plus Bronze Certified 230V Power Supply Unit
DC-to-DC + LLC Circuit Design
High Temperature Resistance
Peak Power Tolerance
80 PLUS Bronze 230V EU Certified
Durable, Reliable, and Safe
5 Year Warranty
  • Category Under 500W
  • Modular Non Modular
  • Fan Bearing HDB
  • 80 Plus Efficiency Bronze
  • PCI-e 6+2 Pin Connectors 2
  • SATA Connectors 6
  • Fan Speed 1500 RPM
  • Efficiency 88% Typically
  • 80 PLUS Rating 80 PLUS Bronze EU 230V
  • Series MWE Bronze Series
  • ATX Version ATX 12V V2.52
  • Protections OVP
  • Protections OPP
  • Hold Up Time >14ms at 100% Full Load@230Vac
  • Noise Level @ 20% 11.18 dBA
  • Protections SCP
  • Noise Level @ 100% 29.5 dBA
  • Noise Level @ 50% 17.1 dBA
  • Protections UVP
  • Protections OTP
  • Input Current 8-4A
  • Input Voltage 200-240Vac
  • Regulatory CCC
  • Regulatory CE
  • Regulatory TUV-RH
  • Regulatory RCM
  • Regulatory EAC
  • Regulatory cTUVus
  • Regulatory FCC
  • Regulatory BSMI
  • Regulatory KC
  • Regulatory CB
  • Model MPE-4501-ACABW-B
