MasterLiquid Pro 140 image number 0
MasterLiquid Pro 140 image number 1
MasterLiquid Pro 140 image number 2
MasterLiquid Pro 140 image number 3
MasterLiquid Pro 140 image number 4
Feel the Flow
  • Note *AMD AM4 upgrade kit needed, please visit: http://bit.ly/31244ne
  • Radiator Material Aluminum
  • Pump L-10 Life 50,000 Hours
  • Pump Rated Voltage 12 VDC
  • Legacy Cooling
  • Pump Noise Level < 12 dBA (Max)
  • Cooler Type Liquid Cooler
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Pump MTTF 175,000 Hours
  • Fan Speed 650-2000 RPM (PWM) ± 10%
  • Fan L-10 Life 70,000 Hours
  • Fan MTTF 490,000 Hours
  • CPU Socket LGA1366
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • Series MasterLiquid Pro
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • Fan Dimensions (L x W x H) 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Dimensions (L x W x H) 171 x 138 x 27 mm / 6.7 x 5.4 x 1.1 inch
  • Fan Air Pressure 3.15 mmH2O (Max)
  • EAN code 4719512052624
  • UPC code 884102028731
  • Product Number MLY-D14M-A22MB-R1
  • Fan Airflow 64.21 CFM (Max)
