MasterFan MF140 Halo² image number 0
MasterFan MF140 Halo² image number 1
MasterFan MF140 Halo² image number 2
MasterFan MF140 Halo² image number 3
Bring On The Light
MasterFan MF140 Halo² White Edition
Cooler Master has redesigned our Dual Loop LED series fan to introduce the new MasterFan MF140 Halo² White Edition.
HYBRID FRAME DESIGN
A hybrid frame structure maintains stability without sacrificing fan blade size or performance.
UPGRADED DRIVER IC
An upgraded driver IC boosts cooling performance while minimizing fan noise.
  • Product Number MFL-B4DW-16NP2-R2
  • Exterior Color White
  • Fan Dimensions (L x W x H) 140 x 140 x 25 mm / 5.5 x 5.5 x 1 inch
  • Fan Speed 0-1600 RPM ± 5%
  • Fan Airflow 59.51 CFM
  • Fan Noise Level 27 dBA
  • Fan Pressure 2.53 mmH₂O
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.13A
  • Fan Safety Current 0.4A
  • Fan Power Consumption 1.56W
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.77A
  • Fan Weight 210g / 0.46 lbs
  • Cooler Type Case Fan
  • Series MasterFan
  • Fan Size 140
  • LED Lighting ARGB
  • Number of LEDs 24pcs
