Bring On The Light
MasterFan MF120 Halo² White Edition
Following the popularity of the MasterFan 120 Halo series, Cooler Master has redesigned our Dual Loop LED series fan to introduce the new MasterFan MF120 Halo² White Edition . The fan blades have been increased by 10% over its predecessor to deliver better air flow and cooling performance. The frame has been designed with a hybrid frame structure to maintain stability without sacrificing fan operational real estate. The driver IC has been upgraded for increased cooling performance while minimizing fan noise. Cooler Master has maintained the elegant Dual Loop LED design featuring our Addressable Gen 2 RGB lighting to give you the most customizable lighting to fit our design needs.
A DUAL NEW WORLD
The MasterFan MF120 Halo² is our redesigned dual loop LED series fan. The MF120 features 10% larger fan blades for improved air flow and cooling performance. The frame has been designed with a hybrid structure that maintains stability without sacrificing operational real estate. An upgraded driver IC is also included for increased cooling performance and minimal fan noise, while the elegant dual loop LED design is maintained via addressable gen 2 RGB lighting that provides the ultimate customizable experience. Enter a dual new world with the MasterFan MF120 Halo².
HYBRID FRAME DESIGN
A hybrid frame structure maintains stability without sacrificing fan blade size or performance.
UPGRADED DRIVER IC
An upgraded driver IC boosts cooling performance while minimizing fan noise.
