MasterFan M Series image number 0
MasterFan M Series image number 1
MasterFan M Series image number 2
MasterFan M Series image number 3
MasterFan M Series image number 4
MasterFan M Series
MasterFan M Series
MasterFan M Series
MasterFan M Series
MasterFan M Series
Seamless Motion. Masterfully Silent.
MasterFan M Series
• Premium aluminum and LCP construction
• Magnetic Dynamic Bearing for ultra-smooth operation
• Extreme silent at high speed
• Discreet integrated RGB light
Unshakable Build. Unstoppable Airflow.
The MasterFan M Series replaces standard plastic with a premium aluminum frame and Liquid Crystal Polymer (LCP) blades. This high-density construction eliminates blade distortion and structural creep, providing uncompromising durability and unwavering high-pressure performance that outlasts conventional cooling solutions.
Zero-Friction Magnetic Precision
Experience near-silent cooling powered by our advanced Magnetic Dynamic Bearing (MDB). By eliminating internal mechanical friction, this next-generation technology guarantees ultra-smooth rotation and an incredibly low noise floor. It delivers the precise acoustic stability required for professional studios and distraction-free gaming.
Specifications - MasterFan M120 ARGB
  • Product Number MFZ-P2DM-20NP2-R1
  • Dimensions 120 x 120 x 30mm
  • LED Profile Addressable RGB Gen.2
  • Speed 0–2300 ± 10% RPM
  • Air Flow 75.2 CFM Max
  • Air Pressure 5.4 mmH₂O Max
  • MTTF >200,000 hours
  • Noise Level 27 dBA Max
  • Bearing Magnetic Dynamic Bearing
  • Connector 4-Pin PWM
  • Rated Voltage 12 VDC
  • Rated Current 0.1A
  • Safety Current 0.2A
  • Power Consumption 1.2W
  • Weight 165g
  • Warranty 5 Years
Specifications - MasterFan M140 ARGB
  • Product Number MFZ-P4DM-16NP2-R1
  • Dimensions 140 x 140 x 30mm
  • Speed 0–1600 ± 10% RPM
  • Air Flow 81 CFM Max
  • Air Pressure 2.39 mmH₂O Max
  • Noise Level 25.9 dBA Max
  • Connector 7-Pin PWM
  • Weight 338g
  • Warranty 5 Years
