MasterBox Pro 5 image number 0
MasterBox Pro 5 image number 1
MasterBox Pro 5 image number 2
MasterBox Pro 5
MasterBox Pro 5
MasterBox Pro 5
You Decide the Inside
MasterBox Pro 5
MasterBox Pro 5
  • Liquid Cooling Support - Rear 120mm
  • Legacy Cases
  • Dust Filters Front
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • I/O Panel 2x USB 3.0
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Liquid Cooling Support - Front 240mm
  • Left Side Panel 4mm Grey Color Tempered Glass
  • Liquid Cooling Support - Front 280mm
  • Clearance - PSU 180mm/7.1"
  • Fan Support - Rear 1x 120mm
  • Liquid Cooling Support - Front 360mm
  • Drive Bays - 2.5" SSD 2
  • Motherboard Support E-ATX
  • Motherboard Support ATX
  • Expansion Slots 7
  • Cable Routing - Behind Motherboard Tray 25-35mm
  • Materials Steel body
  • Clearance - CPU Cooler 167mm/6.5"
  • Materials Plastic bezel
  • Materials Glass
  • Clearance - GFX 410mm/16.1"
  • Dimensions (L x W x H) 500 x 223 x 475 mm
  • Weight 8.3 kg
  • EAN Code 4719512063514
  • UPC Code 884102036194
  • Model Number MCY-B5P2-KWGN-00
