• Products
    ProductsProducts
    • Cooling
      CoolingCooling
      • Air Cooling
      • Liquid Cooling
      • Case Fans
      • Thermal Paste
      • Laptop Cooling
      • Standard Cooler
      • Phone Cooler
    • PC Cases
      PC CasesPC Cases
      • Full Tower
      • Mid Tower
      • Mini Tower
      • Mini ITX
      • PC Case Accessories
    • Power Supplies
      Power SuppliesPower Supplies
      • X Series
      • V Series
      • V SFX Series
      • GX Series
      • MWE Series
      • Elite Series
    • Accessories
      AccessoriesAccessories
      • Monitors
      • Keyboard
      • Mice
      • Audio
      • Mouse pads
      • Controllers
    • Furniture
      FurnitureFurniture
      • Chairs
      • Desk
      • Accessories
    • Systems
      SystemsSystems
      • MasterHub
        MasterHubMasterHub
        • MAX
          MAXMAX
          • ATX
          • Mini ITX
        • Immersive Experience
          Cooling
          360 DEGREES OF COOL
          PC Cases
          CREATED ONLY FOR THE BEST
          Power Supplies
          PRECISE SILENT POWER
          Furniture
          RELAXATION AT YOUR COMMAND
          Systems
          COOL. COMPACT. QUIET.
          MasterHub
          MAX
        • Builder's Zone
          Builder's Zone
          • PSU Calculator
          • CPU Compatibility
          • Guide & Resources
          Builder's Zone
        • Software
          Software
          • Masterplus+
          • Masterctrl
          Software
        • Support
          Support
          • Product registration
          • Tech support
          • Warranty
          • Warranty check
          • Faq
          • Contact us
          Support
          Special Announcement
        HAF 700
        Overview
        1. Home/
        2. PC Cases/
        3. Full Towers/
        4. HAF 700 Full Tower PC Case
        The Berserker
        HAF 700
        • Unparalleled Hardware & Cooling Capabilities
        • Mammoth Water Cooling Support
        • Exclusive Tool-Less Technology
        • ARGB Gen2 ready with MasterPlus+ integration
        IN SPIRIT OF COOLER MASTER'S HAF LEGACY
        HAF 700 embodies the spirit of HAF's performance oriented design, boasting attention to mechanical detail.
        Our Achievements
        14 AWARDS
        Hardware & Connectivity
        No Limits
        The HAF 700 is capable of housing up to SSI-EEB motherboards (E-ATX), as well as any sized graphics cards in BOTH horizontal and vertical orientations.
        Rich Connectivity
        The front I/O is designed to maximize the front connectivity for most high end motherboards, featuring four USB Gen 3.1 Type A ports, a USB Gen 3.2 Type C, a 4 pin audio/mic headset jack as well as a dedicated mic jack.
        Custom Cooling
        6x
        MAMMOTH RADIATOR SUPPORT
        Fans
        Exclusive SickleFlow fans
        HAF 700 comes with dual exclusive 200mm Sickleflow ARGB PWM "Performance Edition" fans tailored to strike a balance between performance potential and noise levels
        Unrestricted Front Panel Intake
        HAF 700 sports a fully meshed front panel, specifically designed
        to allow for maximum air intake. With the front panel structurally
        reinforced to prevent resonation caused by fan vibrations, systems
        can run smoothly at minimal noise levels.
        Effortless Management
        12x
        INTEGRATED HUB
        Installation
        ADVANCED MOUNTING OPTIONS
        The unique removable top panel design allows you to effortlessly install, reach and maintain cooling components such as fans and radiators even in builds with complex custom cooling systems. This, coupled with the rotatable radiator/fan bracket included out of the box allows for an unparalleled building experience.
        Software
        MASTERPLUS+ SOFTWARE INTEGRATION
        Design
        TOOL-LESS INSTALLATION
        Design
        MULTI CHAMBER LAYOUT
        HAF 700's structure segregates non heat sensitive components so heat dissipation can be targeted towards heat sensitive components at an overall higher efficiency.
        ARGB Gen2 Ready, Controller Included
        ARGB Gen2 technology allows users to explore full range customization down to the lighting effecting of each individual LED, while remaining compatible with third party devices.
        Trending
        Hyper 212 Halo Black
        Discover
        MasterLiquid 360 ION
        EXPERIENCE COOLING IN HIGH DEFINITION
        Discover
        MasterBox 600
        Powering Next generation
        Discover
        MWE Gold 850 - V2 Full Modular
        Discover
        • About
          Corporate
          Social Media
          News
          Events
        • Support
          Product Registration
          Tech Spec
          Warranty
          Warranty check
          Faq
          Contact us
          Contact Our Team
        CAREER
        RESOURCE CENTER
        • Privacy policy
        • Terms of use
        • Cookie policy
        • Conformity of products
        Confirm your Country
        The page you're looking shows Cooler Master contents for India.
