Notepal U2 Plus V2 image number 0
Notepal U2 Plus V2 image number 1
Notepal U2 Plus V2 image number 2
Notepal U2 Plus V2 image number 3
Notepal U2 Plus V2 image number 4
Notepal U2 Plus V2
Notepal U2 Plus V2
Notepal U2 Plus V2
Notepal U2 Plus V2
Notepal U2 Plus V2
Updated Laptop Cooler
Notepal U2 Plus V2
Notepal U2 Plus V2 is an updated notebook cooler of its old version that targets your laptop's heat zones with two moveable cooling fans.
  • Product Number MNX-SWUK-20FNN-R1
  • Color Black
  • Material Aluminum, Metalmesh, Plastic, Rubber, Cloth
  • Dimensions (L x W x H) 343 x 266 x 53 mm / 13.5 x 10.5 x 2.1 inch
  • Fan Dimensions (L x W x H) 80 x 80 x 10 mm / 3.2 x 3.2 x 0.4 inch
  • Fan Speed 2000 RPM ± 10%
  • Fan Airflow 31 CFM
  • Fan Noise Level 21 dBA
  • Power USB 5V DC
  • USB USB 2.0/1.1 x 1 (For Power Input)
  • Current Consumption 0.36A
  • Power Consumption 1.8 W
  • Compatibility Supports up to 17" laptops
  • Weight 0.57kg / 1.3lbs
  • Cooler Type Notebook Cooler
  • Series Notepal
