Easy Installation
With pre-installed fans, streamlined cabling, pre-applied thermal paste, and pre-mounted brackets, setup is quick, clean, and effortless.
360 Degrees of Cool
Innovative design
Dual chamber pump
Optimum tubing length
Revamped fans
Updated CPU compatibility
Easy installation
Included Cryo-Fuze thermal paste
An infinity mirror pump cover design brings stylish lighting and a modern touch to your build.
Our patented dual chamber design delivers a compact cooler with efficient and reliable performance.
400 mm tubing allows for effortless cooler installation in any orientation.
Broad compatibility with both Intel and AMD CPU sockets.
