MasterFan MF120 Halo² 3in1 image number 0
MasterFan MF120 Halo² 3in1 image number 1
MasterFan MF120 Halo² 3in1 image number 2
MasterFan MF120 Halo² 3in1 image number 3
MasterFan MF120 Halo² 3in1 image number 4
A Dual New World
MasterFan MF120 Halo² White 3in1
The MasterFan MF120 Halo² White is our redesigned dual loop LED series fan, now available as a 3-in-1 pack, giving you triple the cooling power.
HYBRID FRAME DESIGN
A hybrid frame structure maintains stability without sacrificing fan blade size or performance.
LED CONTROLLER
UPGRADED DRIVER IC
An upgraded driver IC boosts cooling performance while minimizing fan noise.
  • Product Number MFL-B2DW-213P2-R2
  • Exterior Color White
  • Fan Speed 0-2050 RPM ± 5%
  • Fan Airflow 51.88 CFM
  • Fan Noise Level 27 dBA
  • Fan Pressure 2.89 mmH₂O
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.14A
  • Fan Safety Current 0.37A
  • Fan Power Consumption 1.68W
  • RGB Connector 3-Pin ARGB
  • RGB Rated Voltage 5 VDC
  • RGB Rated Current 0.77A
  • Fan Weight 174g / 0.38 lbs
  • Cooler Type Case Fan
  • Series MasterFan
  • Fan Size 120
  • LED Lighting ARGB
