New
MasterLiquid PL240 TR5-SP6
Optimized for AMD Threadrippers
Large, full-coverage copper base
Mobius 120 fans
All-in-one thermal solution
Ultimate Cooling for Extreme Performance
Cooler Master’s high-performance MasterLiquid series is back with the MasterLiquid PL240 TR5-SP6 Edition, a new cooler specifically designed for optimal performance with AMD Threadripper CPUs. Packing our state-of-the-art Mobius 120 fans and an all-in-one design, this latest addition to the MasterLiquid line of products gives you everything you need to buff your machine with a powerful blast of cooling energy. Synergize your AMD build with the MasterLiquid PL240 TR5-SP6.
This edition of the MasterLiquid series has been specially designed for AMD TR5-SP6 CPUs only
The extensive copper base spreads heat more evenly across the cooling surface, allowing for quicker dissipation and maintaining lower CPU temperatures even under heavy loads.
Mobius 120 fans
Our critically acclaimed Mobius 120 fans provide both high-end thermal performance and unparalleled noise control
Pre-applied thermal paste and easy snap-on brackets make installation and set-up a breeze
CPU COMPATIBILITY
