SickleFlow 120 RGB
New Blade Design
Enhanced Fan Frame
Sealed Bearing Structure
Updated Lighting Design
Certified Compatible
£4.99
SickleFlow 120 RGB, a new series of the CoolerMaster Fan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans. Optimized blade design with updated curve that improves air flow and air pressure. Enhanced frame structure, reducing turbulent flow and noise and increasing overall work efficiency. Sealed and secured fan bearing, preventing dust and lubricating oil leakage while increasing the fan’s operation stability and life span.
Enhanced Fan Frame
New Blade Design
Secure Connection
Includes Addressable RGB connector clips to ensure a secure connection
