Surpassing the Standard
I70C for LGA 1700
I70C for LGA 1700 is our popular I70C standard cooler designed for Intel LGA 1700 sockets.
£14.00
STANDARD COOLER I70C FOR LGA 1700
I70C for LGA 1700 is our popular I70C standard cooler designed for Intel LGA 1700 sockets. The compact design is perfect for all-in-one systems and limited form factor builds. The aluminum fins with copper insert provide efficient heat dissipation. 120mm diameter fan has a durable construction designed for extended lifespan, strong airflow, and low noise. Addressable RGB lighting is compatible with various motherboards including Asus AURA Sync, Gigabyte RGB Fusion, MSI Mystic Light Sync and ASRock RGB LED.
Aluminum fins
Addressable RGB Lighting
Compatible with Asus AURA Sync, Gigabyte RGB FUSION, MSI Mystic Light Sync, and ASRock RGB LED
