New
Effortless Efficiency
Elite 302
High in value and attention to detail, Cooler Master’s Elite 302 offers users a cost effective, space conscious solution to gaming and computing needs.
Elite 302 features a large intake grill and 3x 120mm ARGB fans to ensure a smooth, and efficient running system. The fully black coating and included PSU cover allows for clean builds that are visually appealing as well as functional.
£54.00
TOOL-LESS MAGNETIC FRONT PANEL
Quick and easy maintenance with a tool-free magnetic mesh front panel — engineered for airflow and effortless access.
READY FOR HIGH-PERFORMANCE COOLING
Accommodates up to 6 fans and supports 280mm or 360mm radiators to keep your system performing at its peak.
COMPACT SIZE, MAXIMUM COMPATIBILITY
Supports up to 365mm GPUs and 163.5mm CPU coolers – ideal for powerful setups without the bulk.
FRONT I/O USB TYPE-C SUPPORT
Modern connectivity with a built-in USB Type-C port for faster, streamlined data transmission.
ARGB STYLE MEETS PERFORMANCE
Three pre-installed 120mm ARGB fans deliver strong airflow while adding a touch of vibrant lighting to your build.
BREATHABLE PSU SHROUD
Ventilated power supply cover supports both active and passive cooling —
offering flexibility and thermal efficiency.
