• Shop Now
    Shop Now
    • Prebuilt Gaming PCs
    • Special Deals
    Shop Now
    Online Store
  • Products
    ProductsProducts
    • Cooling
      CoolingCooling
      • Air Cooling
      • Liquid Cooling
      • Case Fans
      • Thermal Paste
      • Laptop Cooling
      • Standard Cooler
      • Phone Cooler
      • Accessories
    • PC Cases
      PC CasesPC Cases
      • Full Tower
      • Mid Tower
      • Mini Tower
      • Mini ITX
      • PC Case Accessories
    • Power Supplies
      Power SuppliesPower Supplies
      • X Series
      • V Series
      • V SFX Series
      • GX Series
      • MWE Series
      • Elite Series
    • Accessories
      AccessoriesAccessories
      • Monitors
      • Keyboard
      • Mice
      • Audio
      • Mouse pads
      • Controllers
    • Furniture
      FurnitureFurniture
      • Chairs
      • Desk
      • Accessories
    • Systems
      SystemsSystems
    • MasterHub
      MasterHubMasterHub
      • MAX
        MAXMAX
        • ATX
        • Mini ITX
      • Immersive Experience
        Cooling
        360 DEGREES OF COOL
        PC Cases
        CREATED ONLY FOR THE BEST
        Power Supplies
        PRECISE SILENT POWER
        Furniture
        RELAXATION AT YOUR COMMAND
        Systems
        COOL. COMPACT. QUIET.
        MasterHub
        MAX
      • Builder's Zone
        Builder's Zone
        • PSU Calculator
        • CPU Compatibility
        • Guide & Resources
        Builder's Zone
      • Software
        Software
        • MasterHUB
        • Masterplus+
        • Masterctrl
        Software
      • Support
        Support
        • Product registration
        • Tech support
        • Warranty
        • Warranty check
        • Faq
        • Contact us
        • Return Policy
        • Shipping Policy
        Support
        Special Announcement
      1. Home/
      2. Guide & Resources
      Guide & Resources
      Discover comprehensive guides, tutorials, and resources to enhance your PC building experience. Access expert tips, detailed manuals, and troubleshooting advice to optimize your custom builds. Perfect for beginners and seasoned builders alike.
      COOLING X: CLOUD SERVER QUALITY ON YOUR DESK
      For over 30 years, Cooler Master has led the way in industrial server cooling and pioneered PC components for gamers, creators, and PC enthusiasts. Cooler Master’s Cooling X leverages our experience and the same industrial-grade materials, design, and thermal engineering used in the world's most advanced servers and supercomputers, to deliver a prebuilt system unlike any other.
      A BRIEF OVERVIEW: AI, ML, DL, AND THE GROWING RELEVANCE OF AI PCs
      As we venture further into the rapidly evolving world of personal AI computing, this article will explore the fundamental concepts of Artificial Intelligence (AI) and AI PCs, addressing some of the computational challenges and hardware demands they entail. Leveraging Cooler Master’s expertise in AI server cooling solutions and industry insights, we aim to shed light on the imminent shift towards AI-driven personal computing. Our goal is to use our unique knowledge and technologies to create a seamless AI PC experience.
      What Is ATX 3.1: How Cooler Master Protects Your GPU With The Latest Standard
      The main change that comes with the ATX 3.1 PSU spec is the new 12V-2x6 power connector, which fixes all the reliability issues present in the ATX 3.0 12VHPWR connector.
      Best PC Fan Setups: How To Improve Your Case's Cooling
      How to optimize your PC cooling performance with the best fan configuration.
      WHAT IS ATX 3.0?
      ATX 3.0 is a PSU specification standard released by Intel. ATX 3.0 is optimal for high-power gaming and streaming, and essential for Nvidia 40 series GPUs.
      THE TECHNICAL EVOLUTION OF THE MOBIUS SERIES
      Cooler Master’s in-house designed Mobius series case fans feature several technological evolutions, making them the star of the next generation of cooling technology.
      WHAT IS CYBENETICS NOISE LEVEL?
      Cybenetics calculates a PSU’s overall noise output by averaging testing noise measurements, and then certifying the PSU with a noise level rank.
      ATX OR SFX: WHICH PSU IS RIGHT FOR YOU?
      Generally, SFX PSUs are best for small form factor cases or otherwise compact machines that don’t have much space for other components like cooling systems, while ATX PSUs are for larger, regular cases.
      HOW TO INSTALL A LIQUID COOLER IN YOUR PC
      Installing an AIO CPU liquid cooler in your PC is pretty easy if you follow these steps.
      RGB OR ARGB? WHAT'S THE DIFFERENCE?
      RGB lighting is LED-based lighting that allows for more than 16 million color variations. ARGB lighting allows for more complex lighting displays via control of each individual LED.
      HOW TO CHOOSE A PC CASE?
      When choosing a PC case, it is important to consider the form factor, features, and aesthetics. Ensure that all components will work and fit together properly, and that the case you have selected can support the kind of tasks you want your PC to perform.
      AIO LIQUID COOLING OR AIR COOLING? WHICH SHOULD YOU CHOOSE?
      Air coolers and AIO liquid cooling are both effective methods for cooling your CPU. Which you choose is largely a matter of personal preference.
      HOW TO SAFELY INSTALL A PSU?
      Safely installing a PSU while building your PC is not too complex. If you follow the steps of this guide and your product’s instructions slowly and carefully, everything should go smoothly.
      WHAT IS A PSU?
      A PSU plugs into a wall outlet and converts the AC power supplied to your home into low-voltage regulated DC power to be used by your PC. As the heart that powers the entire machine, the PSU is among the most important components in your PC.
      WHAT IS AN SFX PSU?
      SFX is a small form factor PSU design specification. Small form factor refers to a smaller-than-usual computer component. SFX power supplies are significantly smaller than ATX PSUs.
      WHAT IS AN ATX PSU?
      ATX (Advanced Technology eXtended) is a specification for motherboards, PSUs, and cases. The specification defines sizing, I/O panel location, mounting points, and other factors that ensure each PC component fits together in a standardized way.
      WHAT ARE POST-CONSUMER RECYCLED MATERIALS?
      Post-consumer recycled (PCR) materials are made from consumer recycled materials and are used to make new products. PCR materials can be used in the composition of materials such as aluminum and plastic, and in the manufacturing of packaging, consumer electronic goods, and more.
      WHAT IS 80 PLUS EFFICIENCY?
      80 Plus efficiency is a certification program that proves the efficiency of PC power supply units. An 80 Plus certified unit is guaranteed to be at least 80% efficient at loads of 20%, 50%, and 100%.
      HOW TO CHOOSE A PSU?
      When building a PC, you need to know the 3 most important factors for choosing a PSU: wattage, form factor, and efficiency. We have compiled a list of the 3 most important factors to consider when choosing a PSU for your build.
      THE POWER OF SUPERCONDUCTIVE COMPOSITE HEAT PIPES
      CPU coolers are one of the most important components that ensure a powerful PC can run smoothly. The CPU is the brain of every PC and if it overheats it will cease to work properly, effectively shutting down the entire machine.
      • About
        Corporate
        Social Media
        News
        Events
      • Support
        Product Registration
        Spare Parts Store
        Tech Spec
        Warranty
        Warranty check
        Faq
        Contact us
      CAREER
      RESOURCE CENTER
      • Privacy policy
      • Terms of use
      • Cookie policy
      • Conformity of products
      Confirm your Country
      The page you're looking shows Cooler Master contents for United Kingdom.
