Silencio Design
The Silencio’s minimalistic design cloaks its complexity. Design elements fine-tuned in form and function result in minimized noise and efficiently maintained system temperatures.
![](https://a.storyblok.com/f/281110/845x860/bea6c2625d/s400-sec1-1.png/m/845x0/smart)
Silencio Design
Silencio Technology
Sound Dampening Material
Top & Front Ventilation
Reversible Steel Door
The front panel features a recurved vent, directing air in through the front bezel. The curve points downward, taking air in from the bottom, and straightens out to direct air in from either side of the steel front door.
The HDD cage is (re)movable. The cage can be shifted forward to make room for a longer PSU, backwards for additional radiator space, or completely removed if HDD storage is not needed.
Mini-ITX, Micro-ATX
Fans
Radiators
Top:
120 / 140mm x 1 Fans
120 / 140mm x 2 Fans (remove ODD cage)
120 / 240* Radiator
*remove ODD cage
Front:
120 / 140 / 240 / 280* Radiator
*may interfere with HDD mounted below ODD bracket
Rear:
120 x 1 Fan
120 x 1 Radiator
5.25” ODD x 1 (ODD version)
3.5” HDD x 4
2.5” SSD x 4
CPU Cooler (Steel): 167mm
CPU Cooler (TG): 166mm
Power Supply:
325mm (w/o front radiator & HDD cage)
140mm (HDD cage in backmost position)
Graphics Card: 319mm
