Elevated Performance
Notepal X150 Spectrum
The Notepal X150 Spectrum is our cooling pad developed with performance and utility for your portable system.
€39.99
The Notepal X150 Spectrum is Here
Cooler Master's Notepal X150 Spectrum combines performance, looks, and functionality into the perfect cooling pad for your portable system. Built with a metal mesh foundation and ideal elevated incline, it gives you stability as well as maximum airflow for efficient heat dissipation.
Metal Mesh Contact Surface
Metal base provides solid support and breathability to cool your device
Ideal Cooling Engineering
Elevated incline promotes increased ventilation and heat dissipation
Quiet Performance
Impressive 160mm fan cools your system at unnoticeably quiet operation
Vibrant LED
Light up your system with a touch of vibrancy with multicolor LED lighting
Ample Connectivity
Integrated connectivity allows for 3 USB and 1 USB Type-C interface to connect all your accessories
Supports Various Sizes
Supports up to 17" laptops
