More Balance, More Burst
Mobius 120P ARGB 3-pack Fan Kit
  • Ring Blade Design (RBD)
  • Pressure Air Acceleration
  • Absolute Acoustics
  • Luminescent Light Effects
  • Addressable Gen 2 RGB
  • New Mini A1 controller
€79.99
PERFECTING ENGINEERING
Cooler Master’s Mobius 120P ARGB is a part of our highest performing series of fans. With an innovative ring blade design, the Mobius series optimizes for both performance and acoustics. Catering to a wide range of applications, cases, and cooling set ups, the Mobius 120P can suit the needs of any build.
RING BLADE DESIGN (RBD)
LOOP DYNAMIC BEARING
OIL REFLOW
ANTI-SWAY SYSTEM
DUST PROOFING
PRESSURE AIR ACCELERATION
An angled inner frame rim with chamfered side vents boosts air intake, maximizes air flow, and eliminates dead spots.
ABSOLUTE ACOUSTICS
Sound output fine tuned to the optimal prominence ratio to achieve sub 6dB noise levels without performance sacrifice.
Acoustic Testing
Anechoic Chamber for ISO 3745
• Sound Pressure: IS0-7779
• Sound Power: ISO-7779
ANTI-VIBRATION DAMPER
Our Achievements
10
AWARDS
Addressable Gen 2 RGB syncs with Cooler Master’s MasterPlus+ software and dedicated controller, allowing customization of individual LED colors, effects, brightness and more – all from an intuitive, convenient interface.
(controller sold separately)
NEW MINI A1 ARGB CONTROLLER
The brand new mini A1 controller is small, convenient, and easily allows you to daisy chain and connect up to three Mobius 120P fans. Compatible with our MasterPlus software, it allows full customization, all the way down to individual LED effects, brightness, and more.
