New
Promo
MasterBox 600 Lite + Mobius 120 Fan x 4 + G Gold 750 V2 Full Range Power Supply Bundle
Masterbox 600 Lite + Mobius 120 fan + G Gold 750 V2 Full Range
Upgrade your PC build with this powerful bundle featuring the MasterBox 600 Lite, the high-performance Mobius 120 Fan, and the reliable G Gold 750 V2 Full Range Power Supply. Designed for optimal cooling and power efficiency, this bundle is perfect for PC enthusiasts and gamers. Explore more about this exclusive offer now!
€169.00
MasterBox 600 Lite
Mobius 120 Black
Improved Design
Back-connected motherboard support
MasterBox 600 Lite support back-connected motherboard to frees up space in the front of the case and providing improved cable management space up to 33~35mm behind MB tray.
Pressure Acceleration Air Vents
Angled inner frame rim with chamfered side vents boost airflow draw, The structural ring blade eliminates any fan deformation- Ring Blade keeps the fan build structure rigid, inflexible, stiff and rigor 45 deg Q in and Q out, larger air flow in and air flow out increasing the Q
Exceptional Efficiency
The G Gold V2 is certified to achieve more than 90% efficiency at typical loads.​​
