New
PRECISE SILENT POWER
X Silent Edge Platinum 850
• Fanless Design for Absolute Silence
• Patented Heat Pipe Dissipation
• Minimize Electromagnetic Noise
• Industrial-Grade Infineon IC
• Digital Power Management System
• 15-year warranty
Precise Silent Power
Engineered with a fanless design and industrial IC components, X Silent Edge Platinum features out Heat Pipe Dissipation Patent, ensuring quietness for even the most noise-sensitive environments.
No Fan, No Dust
Equipped with a heat pipe and an innovative modular thermal structure, our design enhances thermal efficiency, essential for the low-temperature rise of key components and the ultra-quiet fanless operation.
Fully Modular Cabling
Modular cabling minimizes clutter, while the additional ports provide extra functionality.
Patented Heat Decentralized Design
Our Private Aluminum Thermal Mold effectively dissipates heat, and the Innovative Heat Pipe Thermal Tech uniformly regulates unit temperature. This ensures superior thermal control, enhancing efficiency and longevity in demanding environments.
Patented Copper-Aluminum Heat Dissipation
In-house designed composite heat pipe technology enables effective passive thermal management.
Digital Power Management System & MasterCTRL
Equipped with MCUs and Integrated with MasterCTRL software, our reliable PSU meticulously monitors temperature, current load and efficiency in real-time, offering precise and direct oversight.
Active Bridge Rectifier Boosts Efficiency 2%
The Active Bridge Rectifier, equipped with the Infineon CoolMOS, marks a significant advancement in power efficiency. This innovative combination not only conserves electricity, but also significantly reduces power loss, outperforming traditional bridge diodes. It's an ideal solution for users seeking eco-friendly, high-efficiency power supply units.
ATX 3.1 Support & A Dual-color 90° 12V-2X6 Cable
Includes ATX 3.1 support and a dual-color 12V-2x6 connector (with clear purple markings) help users confirm correct installation, preventing poor contact and power issues for enhanced safety and reliability.
PSU Calculator
