Vertical Graphics Card Holder Kit image number 0
Vertical Graphics Card Holder Kit image number 1
Vertical Graphics Card Holder Kit image number 2
Make of It What You Will!
  • Graphics card capacity One graphics card per holder
  • Requirement Requires seven PCI case slots
  • Riser Cable Model Riser Cable PCIe 3.0
  • Support PCI area of your Case
  • Net Weight 0.230Kg
  • Color(s) Dark Metallic Grey
  • Legacy Accessories
  • Note This product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
  • Materials SGCC Steel
  • Dimensions (L x W x H) 170 x 145 x 120 mm
  • Model Number MCA-U000R-KFVK00
