Vertical Graphics Card Holder Kit V3 (PCIE 5.0) image number 0
Vertical Graphics Card Holder Kit V3 (PCIE 5.0) image number 1
Vertical Graphics Card Holder Kit V3 (PCIE 5.0) image number 2
Vertical Graphics Card Holder Kit V3 (PCIE 5.0) image number 3
Vertical Graphics Card Holder Kit V3 (PCIE 5.0) image number 4
Make of it what you will
• PCIe 5.0 riser cable included​
• Showcase your GPU with style​​
• ATX & m-ATX case compatibility​​
• Tool-less, flexible adjustment​
• Premium steel, 42%more durable​
• Simplified installation​
  • Product Name VERTICAL GRAPHICS CARD HOLDER KIT V3 PCIE 5.0 X16 165MM
  • Color(s) Black / White
  • Model Number Black: MCA-U000C-KFVK03
  • Model Number White: MCA-U000C-WFVK03
  • Dimensions (L x W x H) GFX Holder Kit: 249 x 148.1 x 141.8 mm (Close Size), 305 x 178.1 x 141.8 mm (Open Size), Riser Cable: 165 mm
  • Supported Chassis Type E-ATX, ATX , Micro ATX (may interfere with component installation on the rear panel. Max. CPU cooler height limited to 70mm.)
  • Supported Graphics Cards Any length, up to 3 slots wide
  • Component Materials PCBA, silver-plated Copper Wire 30 AWG
  • Insulation Materials FEP (Cable), PA10T + 35%GF (Connector)
  • Other Materials ABS, PP, SGCC Steel, Nickel, Gold, Brass
  • Compatibility PCIe 5.0 and older
  • CE Certifications Number BKC25093934JC
  • PCB / Wire UL Numbers E467745 / E527405
  • Connectors PCIe x16 Male to PCIe x16 90° Female
  • Required PCI slots Minimum 4 PCI slots required for mounting
  • Working Voltage / Current DC 12V / 3.3V/3.3Vaux A,75W(Max)
  • Operating Temperature -20° to +80° Celsius
  • Net Weight 0.81 kg
  • Gross Weight 1.03 kg
  • Warranty 1 year
