V8 ACE 3DHP image number 0
V8 ACE 3DHP image number 1
V8 ACE 3DHP image number 2
V8 ACE 3DHP image number 3
V8 ACE 3DHP image number 4
V8 ACE 3DHP image number 5
V8 ACE 3DHP image number 6
V8 ACE 3DHP image number 7
V8 ACE 3DHP
V8 ACE 3DHP
V8 ACE 3DHP
V8 ACE 3DHP
V8 ACE 3DHP
V8 ACE 3DHP
V8 ACE 3DHP
V8 ACE 3DHP
Raw Power. Refined Thermals.
V8 ACE 3DHP
Cooler Master Proprietary 3DHP Technology​
Intel / AMD Contact-Optimized Base
Dual 120mm LCP PWM Fans
High-Density Thermal Fin Stack
Engine-Inspired Aluminum Covers
3DHP INNOVATION
3DHP design helps move heat away from the CPU more efficiently, keeping performance steady during rendering, AI tasks, and long production runs.
SMALLER FOOTPRINT. DUAL-TOWER-CLASS AMBITION.
3DHP technology allows V8 ACE 3DHP to achieve high thermal efficiency in a much more compact size.
More Air Through The Stack
Two 120 x 30 mm PWM fans push air through the fin stack for stronger airflow under load.
Made for your platform
Dedicated Intel and AMD versions use platform-specific brackets for better fit and improved CPU contact.
Stable Blades. Steady Cooling.
LCP fan blades maintain their shape at high speed,
helping keep airflow steady and cooling performance
more consistent under load.
Controlled Acoustic Performance
Delivers strong cooling performance with a max noise level of 37 dB(A).
Clean Flagship Aesthetic
The non-RGB design delivers a refined premium look
that fits creator workstations and enthusiast builds.
  • Product Name V8 ACE 3DHP
  • Product Number Intel Black: MAM-T6HP-225PK-RB / Intel White: MAM-T6HP-225PK-RW; AMD Black: MAM-T6HA-225PK-RB / AMD White: MAM-T6HA-225PK-RW
  • Exterior Color Black / White
  • CPU Socket AMD® AM5 / AM4; Intel® LGA 1851 / 1700 / 1200 / 1151 / 1150 / 1155 / 1156
  • Heat Sink Material 2 x 3DHP / 4 x Heat Pipes / Aluminum Fins
  • Fan Dimensions (L x W x H) 120 x 120 x 30 mm / 4.7 x 4.7 x 1.18 in
  • Fan Quantity Front: 1, Rear: 1
  • Fan Airflow Front: 152.23 m³/h / 89.6 CFM, Rear: 103.64 m³/h / 61.0 CFM
  • Fan MTTF >200,000 Hours
  • Fan Safety Current Front: 0.4 A, Rear: 0.2 A
  • Warranty 6 Years
  • Fan Size 120
  • Cooler Type Air Cooler
  • Dimension 138.95 x 136.47 x 167.3 mm / 5.47 x 5.37 x 6.58 in
  • Fan Item Front / Rear
  • Fan LED Profiles Non-LED
  • Fan Speed Front: 0-2500 ± 250 RPM, Rear: 0-2050 ± 250 RPM
  • Fan Pressure Front: 3.85 mmH₂O, Rear: 2.0 mmH₂O
  • Fan Noise Level Front: 37 dB(A), Rear: 34 dB(A)
  • Fan Rated Current Front: 0.2 A, Rear: 0.13 A
  • Fan Power Consumption Front: 2.4 W, Rear: 1.56 W
  • Series V
  • Heatpipes 6 Total: 2 x 3DHP + 4 x Heat Pipes
