Flexible compatibility
With the included SFX-to-ATX bracket, the V SFX Gold ATX 3.1 can be used to power systems ranging from as small as a mini-ITX all the way up to E-ATX motherboards.
• Flexible compatibility
• 80 PLUS Gold certified
• Fully modular cabling
• 100% Japanese capacitors
• 10-year Warranty
As the leading SFX power supply design, the V SFX Gold offers a highly powerful unit in a space-saving, mini form factor.
Includes ATX 3.1 support and a 90-degree 12+4pin (12V-2x6) PCIe 5.1 connector featuring higher electrical durability, lower temperatures, and improved safety.
The V SFX Gold is certified to achieve more than 90% efficiency at typical loads.
Large, high-quality Japanese capacitors feature improved efficiency
and reduced ripple noise.
