Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 0
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 1
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 2
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 3
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 4
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 5
Universal Vertical GPU Holder Kit V2 (PCIe 4.0) image number 6
Make of It What You Will
Cooler Master Riser Cable PCIe 4.0 Included
Showcase Your Graphics Card
Compatible With All Standard ATX Chassis
Modular, Instantly Adjustable Design
Durable, High Quality Materials
  • Model Number MCA-U000R-KFVK02
  • Color(s) Black / Purple
  • Dimensions (L x W x H) GFX Holder Kit: 184 x 142 x 121mm (closed), GFX Holder Kit: 239 x 142 x 121mm (fully open), Riser Cable: 165mm (6.19in)
  • Supported Graphics Cards Any length, up to 2.5 slots wide
  • Riser Cable Model Riser Cable PCIe 4.0 x16
  • Compatibility PCIe 4.0 and older
  • CE Certifications Number BKC210933AC
  • PCB / Wire UL Numbers E189572 / E252840
  • Electronic Component Materials PCBA, Tinned Copper Wire 30 AWG
  • Insulation Materials PE, TPE
  • Other Materials ABS, PP, SGCC Steel, Nickel, Gold, Brass
  • Connectors PCIe x16 Male to PCIe x16 90° Female
  • Rated Working Voltage and Current DC 12V / 5A
  • Operating Temperature -20° to +100° Celsius
  • Required PCI slots 7 PCI slots are required for mounting
  • Weight 0.43 kg
  • Warranty 1 year
  • Series Others
