SickleFlow X (Green LED) image number 0
SickleFlow X (Green LED) image number 1
  • Fan Power Connector 3-Pin
  • Adapter 3 to 4 pin Adapter x 1
  • Fan Life Expectancy 160,000 Hours
  • Cooler Type Case Fan
  • LED Lighting LED
  • Fan Size 120
  • Fan Bearing Type POM Bearing - Cooler Master 4th Gen. bearing (*POM: Polyoxymethelene)
  • Note Model number and spec might be slightly different between regions
  • Accessory Metal Screw x 4
  • Fan Weight 109g
  • Series SickleFlow
  • Fan Noise Level 19 dBA
  • Fan Speed 2000 RPM ± 10%
  • Fan Rated Current 0.35A
  • Fan Power Consumption 4.2W
  • Fan Air Pressure 2.94 mmH2O
  • Product Number R4-SXDP-20FG-R1
