RGB LED Controller image number 0
RGB LED Controller image number 1
RGB LED Controller image number 2
RGB LED Controller
RGB LED Controller
RGB LED Controller
Cool with Your Color
RGB LED Controller
The RGB LED Controller together with Cooler Master software allows you to take full control of your rig’s lighting and take it to the next level.
  • RGB LED Controller - Dimensions 90 x 53 x 14 mm / 3.54 x 2.08 x 0.55 inch
  • Material Plastic
  • Control Method Cooler Master Software
  • Input Connector SATA Power
  • Output Channel Voltage 12V
  • Output Channels 4
  • Lighting Mode Static
  • Included Accessories 450 mm Extension Cable x 4
  • Interface USB connectors (9 Pin)
  • Included Accessories 600 mm Extension Cable x 1
  • Lighting Mode Breathing
  • Output Channels Port 1, 2 for Frequency Control
  • Material PCB
  • Lighting Mode Color Cycle
  • Lighting Mode Stars
  • Warranty 5 years
  • Lighting Mode Customize
  • Lighting Mode Multilayer
  • Cooler Type RGB Accessories
  • Lighting Mode Turn LED Off
  • Lighting Mode Mirage (Frequency Control)
  • Weight 122g
  • Series RGB Accessories
  • Product Number MFY-RCSN-NNUDK-R1
