• Products
    ProductsProducts
    • Cooling
      CoolingCooling
      • Air Cooling
      • Liquid Cooling
      • Case Fans
      • Thermal Paste
      • Laptop Cooling
      • Standard Cooler
      • Phone Cooler
      • Accessories
    • PC Cases
      PC CasesPC Cases
      • Full Tower
      • Mid Tower
      • Mini Tower
      • Mini ITX
      • PC Case Accessories
    • Power Supplies
      Power SuppliesPower Supplies
      • X Series
      • V Series
      • V SFX Series
      • GX Series
      • MWE Series
      • Elite Series
    • Accessories
      AccessoriesAccessories
      • Monitors
      • Keyboard
      • Mice
      • Audio
      • Mouse pads
      • Controllers
    • Furniture
      FurnitureFurniture
      • Chairs
      • Desk
      • Accessories
    • Systems
      SystemsSystems
      • MasterHUB
        MasterHUBMasterHUB
        • MAX
          MAXMAX
          • ATX
          • Mini ITX
        • Immersive Experience
          Cooling
          360 DEGREES OF COOL
          PC Cases
          Premium Modular ATX Case
          Power Supplies
          PRECISE SILENT POWER
          Furniture
          RELAXATION AT YOUR COMMAND
          Systems
          COOL. COMPACT. QUIET.
          MAX
        • Builder's Zone
          Builder's Zone
          • PSU Calculator
          • CPU Compatibility
          • Guide & Resources
          Builder's Zone
        • Software
          Software
          • MasterHUB
          • Masterplus+
          • Masterctrl
          Software
        • Support
          Support
          • Product registration
          • Tech support
          • Warranty
          • Warranty check
          • Faq
          • Contact us
          Support
          Special Announcement
        Mobius 120P ARGB
        Overview
        1. Home/
        2. Cooling/
        3. Case Fans/
        4. Mobius 120P ARGB Case Fan
        More Balance, More Burst
        Mobius 120P ARGB
        Ring Blade Design (RBD)
        Pressure Air Acceleration
        Absolute Acoustics
        Luminescent Light Effects
        Addressable Gen 2 RGB
        PERFECTING ENGINEERING
        Cooler Master’s Mobius120P ARGB is our new series of performance fans. With our enhanced Ring Blade Design, the Mobius Series optimizes both performance and acoustics, catering to a dynamic range of applications from case, liquid or air, to overclocking and intense gaming.
        RING BLADE DESIGN (RBD)
        PRESSURE AIR ACCELERATION
        Angled inner frame rim with chamfered side vents boost airflow draw, maximizing force induced air pressure and diminishing dead air.
        LOOP DYNAMIC BEARING
        ANTI-VIBRATION DAMPER
        ABSOLUTE ACOUSTICS
        Sound output fine tuned to the optimal prominence ratio
        to achieve sub 6dB noise levels without performance sacrifice.
        Acoustic Testing
        Anechoic Chamber for ISO 3745
        • Sound Pressure: IS0-7779
        • Sound Power: ISO-7779
        OIL REFLOW
        DUST PROOFING
        ANTI-SWAY SYSTEM
        ANTI-SWAY SYSTEM
        Trending
        New
        MasterFrame 600
        Premium modular ATX case
        Discover
        • About
          Corporate
          Social Media
          News
          Events
        • Support
          Product Registration
          Tech Spec
          Warranty
          Warranty check
          Faq
          Contact us
        CAREER
        RESOURCE CENTER
        • Privacy policy
        • Terms of use
        • Cookie policy
        • Conformity of products
        Confirm your Country
        The page you're looking shows Cooler Master contents for Australia.
