MM712 30th Anniversary Edition Gaming Mouse image number 0
MM712 30th Anniversary Edition Gaming Mouse image number 1
MM712 30th Anniversary Edition Gaming Mouse image number 2
MM712 30th Anniversary Edition Gaming Mouse image number 3
MM712 30th Anniversary Edition Gaming Mouse image number 4
MM712 30th Anniversary Edition Gaming Mouse image number 5
MM712 30th Anniversary Edition Gaming Mouse image number 6
Lightweight Prestige
The MM712 is the next evolution of our first popular lightweight mouse, leveled up to lightweight prestige.
  • Product Number MM-712-KCOH1
  • Mouse Grip Type Palm / Claw
  • Mouse Material ABS Plastic / Rubber / PTFE
  • Mouse LED Color 16.7 Million RGB
  • Mouse Sensor PixArt Optical Sensor
  • CPI / DPI 400-800-1200(Default)-1600-3200-8000-19000
  • Mouse Tracking Speed 400 ips
  • Mouse Lift Off Distance < ~2mm / Adjustable
  • Mouse Polling Rate 2.4GHz/Wired Mode: 1000 Hz, BT Mode: 125 Hz
  • Angle Snapping Yes
  • Mouse acceleration 50g
  • Mouse Lifespan (L/R switches) Optical Switches, 70 Million
  • Mouse Buttons 6
  • Connectivity Wired / 2.4GHz / Bluetooth 5.1
  • Battery 500 mAh
  • Battery Life Bluetooth Mode: 180hrs (with LED Off), 2.4GHz Mode: 80hrs (with LED Off)
  • Charging Support Wired charging
  • Compatible OS Windows 8+ / macOS / Andriod / iOS
  • Software Yes, Cooler Master MasterPlus+ Support
  • Mouse Cable Detachable Ultraweave Cable, 1.8 M (Type-C to Type-A) with Gold-plated
  • Dimensions (L x W x H) 116.5 x 62.4 x 38.3 mm / 4.6 x 2.5 x 1.5 inch
  • Mouse Weight < 58g / 0.13 lbs (w/o Dongle & Cable)
  • Product Mice
