MasterLiquid ML240L V2 RGB image number 0
MasterLiquid ML240L V2 RGB image number 1
MasterLiquid ML240L V2 RGB image number 2
MasterLiquid ML240L V2 RGB image number 3
MasterLiquid ML240L V2 RGB image number 4
MasterLiquid ML240L V2 RGB image number 5
CoolerMaster MasterLiquid ML240L RGB V2 is a refreshed design from the popular MasterLiquid Lite Series that elevates the exterior design elements. The Pump of the ML240L RGB V2 has been enhanced with the newly designed 3rd Gen. Dual Chamber Pump that improves the overall cooling efficiency of the AIO water cooler. The radiator surface area has been enlarged to increase the surface area for heat dissipation for optimized cooling performance. The ML240L RGB V2 will included the latest SickleFlow 120 RGB fan with a brand new design and Air Balance fan blades that is quieter than before without compromising on air flow and pressure.
  • Product Number MLW-D24M-A18PC-R2
  • Exterior Color Black
  • CPU Socket Intel® LGA 1851 / 1700 / 1200 / 2066 / 2011-v3 / 2011 / 1151 / 1150 / 1155 / 1156 socket
  • CPU Socket AMD® AM5 / AM4 / AM3+ / AM3 / AM2+ / AM2 / FM2+ / FM2 / FM1 socket
  • Radiator Material Aluminum
  • Radiator Dimensions 277 x 119.6 x 27.2 mm / 10.9 x 4.7 x 1.1 inch
  • Pump Dimensions 79.9 x 76 x 47 mm / 3.1 x 3 x 1.9 inch
  • Pump MTTF 70,000 Hours
  • Pump Noise Level < 10 dBA (Max)
  • Power Connector 3-Pin
  • Pump Rated Voltage 12 VDC
  • Pump Power Consumption 2.36 W
  • Fan Quantity 2 PCS
  • Fan LED RGB
  • Fan Speed 650-1800 RPM ± 5% (Max)
  • Fan Airflow 62 CFM (Max)
  • Fan Noise Level 27 dBA
  • Fan Pressure 2.5 mmH₂O (Max)
  • Fan Life Expectancy 160,000 Hours
  • Fan Rated Current 0.15A
  • TDP 180 W
  • RAM Clearance N/A
  • Note Compatible with AMD AM5 although the older boxes may not stress it.
  • Cooler Type Liquid Cooler
  • Series MasterLiquid Lite
  • Radiator Size 240
