MasterLiquid Maker 92 image number 0
MasterLiquid Maker 92 image number 1
MasterLiquid Maker 92 image number 2
MasterLiquid Maker 92 image number 3
MasterLiquid Maker 92 image number 4
MasterLiquid Maker 92 image number 5
MasterLiquid Maker 92 image number 6
MasterLiquid Maker 92 image number 7
Compact Cooling, with a Twist
  • Radiator Material Aluminum
  • Pump L-10 Life 50,000 Hours
  • Pump Rated Voltage 12 VDC
  • Vertical Dimension 99.9 x 81.6 x 167.5mm / 3.9 x 3.2 x 6.6”
  • Horizontal Dimension 99.9 x 142 x 118.8 mm / 3.9 x 5.6 x 4.7”
  • Power Connector x6 = 2x (400+120+120mm)
  • Legacy Cooling
  • Power Connector 4-Pin
  • Pump Noise Level < 12 dBA (Max)
  • Cooler Type Liquid Cooler
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Pump MTTF 175,000 Hours
  • Warranty 5 years
  • Fan MTTF 350,000 Hours
  • Weight 875g
  • Fan Dimensions (L x W x H) 95 x 95 x 25.4 mm / 3.7 x 3.7 x 1 inch
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • Series MasterLiquid Maker
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • Fan Speed 550-2600 RPM (PWM) ± 10%
  • Fan Air Pressure 6.4 mmH2O (Max)
  • EAN code 4719512053690
  • UPC code 884102029783
  • Fan Airflow 49.7 CFM (Max)
  • Product Number MLZ-H92M-A26PK-R1
