SMART COOLING, SIMPLE CONTROL
MASTERLIQUID CORE NEX DIGITAL SERIES
Dual Chamber Pump
Innovative, Smart Design
Easy Installation​
Universal Socket Support​
Optimum Tubing Length
Experience next-level cooling with the MasterLiquid Core Nex Digital Series. Built for PC builders, gamers, and professionals, it delivers reliable cooling performance with quiet efficiency and a bold hexagonal digital display that merges form and function. The integrated digital panel provides real-time system insights, allowing you to monitor CPU usage, temperatures, fan and pump speeds through a clean, modern interface. With MasterCTRL software, you can easily customize and control your display setting. Combining dependable technology with sleek aesthetics, the MasterLiquid Core Nex Digital Series offers cooling that’s smart, stylish, and made for everyone.
3 x 120mm fans
MasterLiquid Core Nex Digital 360 Black ARGB
3 x 120mm fans
MasterLiquid Core Nex Digital 360 White ARGB
2 x 120mm fans
MasterLiquid Core Nex Digital 240 Black ARGB
2 x 120mm fans
MasterLiquid Core Nex Digital 240 White ARGB
INNOVATIVE, SMART DESIGN
Featuring a digital pump cover with real-time system stats and a bold hexagonal outer ring for instant CPU usage at a glance. Customize your display with our MasterCTRL software, which lets you easily adjust data sources. Whether it’s fans, pumps, CPU, or GPU, everything is under your control.
Dual chamber pump
Patented design
Improved Quality
Dual Chamber Pump
Our patented dual chamber design delivers a compact cooler with efficient and reliable performance.
400 mm tubing allows for effortless cooler installation in any orientation.
Easy Installation
With pre-installed fans, streamlined cabling, pre-applied thermal paste, and pre-mounted brackets, setup is quick, clean, and effortless
Broad compatibility with both Intel and AMD CPU sockets
Pre-Applied CryoFuze Thermal Paste
Tube Clips Included
