MasterLiquid 240 ATMOS White image number 0
MasterLiquid 240 ATMOS White image number 1
MasterLiquid 240 ATMOS White image number 2
360 Degrees of Cool
Cooler Master is unveiling the next generation of liquid cooling engineering with the MasterLiquid 240 Atmos White, our new AIO liquid cooler
Design
Fully customizable
Customize the pump top cover with your 3D designs and take full control of the ARGB Gen 2 lighting. The Atmos provides unprecented creative freedom.
Cooling System
DUAL
CHAMBER DESIGN
Eco-friendly construction
Our Achievements
8 awards
Fans
LATEST SICKLEFLOW EDGE 120 FANS
Pre-installed SickleFlow Edge 120mm fans further improve cooling performance and simplify user installation.
Optimized User Experience
Service
With features such as our streamlined MasterCTRL software and modernized packaging techniques, the Atmos is bringing a overhauled, and smoother,user experience.
Discover MasterCTRL
  • Product Number MLX-D24M-A25PZ-RW
  • Exterior Color White
  • Radiator Material Aluminum
  • Radiator Dimensions 277 x 119.6 x 27.2 mm / 10.9 x 4.7 x 1.1 inch
  • Pump Dimensions 84.9 x 81 x 53.15 mm / 3.3 x 3.2 x 2.1 inch
  • Pump MTTF >210,000 Hours
  • Pump Connector 4-Pin
  • Pump Rated Voltage 12 VDC
  • Fan Quantity 2 PCS
  • Fan LED Type ARGB
  • Fan Airflow 70.7 CFM (Max)
  • Fan Pressure 3.61 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Rated Current 0.2A
  • Fan Safety Current 0.3A
  • RAM Clearance N/A
  • Warranty 5 years
  • Cooler Type Liquid Cooler
  • Series MasterLiquid
  • Radiator Size 240
