MasterFan MF120R ARGB image number 0
MasterFan MF120R ARGB image number 1
MasterFan MF120R ARGB image number 2
MasterFan MF120R ARGB image number 3
MasterFan MF120R ARGB image number 4
MasterFan MF120R ARGB image number 5
LIVE YOUR LIFE IN THE MOST COLORFUL WAY
MasterFan MF120R ARGB, a new member of the MasterFan family, provides a specific air cooling solution ideal for CPU coolers and chassis in-take fans.
  • RGB Rated Voltage 5 VDC
  • LED Lighting ARGB
  • Cooler Type Case Fan
  • Fan Bearing Type LDB
  • Fan L-10 Life 40,000 Hours
  • Fan Speed 650-2000 RPM (PWM) ± 10%
  • RGB Rated Current 0.34A
  • Fan Size 120
  • Fan MTTF 280,000 Hours
  • Fan Safety Current 0.54A
  • Series MasterFan
  • Fan Weight 137g
  • Fan Rated Current 0.2A
  • Fan Air Pressure 2.14 mmH2O
  • Fan Airflow 59 CFM ± 10%
  • Product Number R4-120R-20PC-R1
  • Fan Noise Level 31 dBA
