MasterFan MF120 Prismatic image number 0
MasterFan MF120 Prismatic image number 1
MasterFan MF120 Prismatic image number 2
MasterFan MF120 Prismatic image number 3
Crystal Clear Performance
MasterFan MF120 Prismatic features a tri-loop Addressable RGB lighting with distinctive crystallization on both sides.
  • RGB Rated Voltage 5 VDC
  • LED Lighting ARGB
  • RGB Connector 3-Pin ARGB
  • Fan MTTF 160,000 Hours
  • Fan Bearing Type LDB
  • Cooler Type Case Fan
  • Fan Safety Current 0.37A
  • Fan Size 120
  • RGB Rated Current 0.65A
  • Note Products manufactured after 1st June 2021 are Addressable Gen 2 RGB LEDs
  • Fan Profiles Addressable Gen 2 RGB
  • Fan Rated Current 0.12A
  • Fan Power Consumption 1.44W
  • Number of LEDs 30pcs
  • Series MasterFan
  • Fan Weight 153g / 0.34 lbs
  • Fan Noise Level 8 - 27 dBA
  • Fan Speed 650-2000 RPM ± 5%
  • Fan Air Pressure 2.91 mmH2O (Max)
  • Fan Airflow 55 CFM (Max)
  • Product Number MFY-B2DN-20NPA-R1
