MasterFan ARGB and PWM HUB image number 0
MasterFan ARGB and PWM HUB image number 1
MasterFan ARGB and PWM HUB image number 2
MasterFan ARGB and PWM HUB image number 3
MasterFan ARGB and PWM HUB image number 4
MasterFan ARGB and PWM HUB image number 5
Giving You More For Less
The new MasterFan ARGB and PWM HUB is capable of connecting up to 6 sets of Addressable RGB (3-pin) headers and PWM headers simultaneously...
  • Power Connector x6 = 2x (400+120+120mm)
  • RGB Rated Voltage 5 VDC
  • RGB Safety Current 2.0 A (1 Port) / Total 4.5 A ( 6 Ports)
  • Power Safety Current 4.5 A (Max)
  • Fan Connector 6 Ports x 4 Pin PWM
  • RGB Connector 6 Ports x 3 Pin Addressable RGB
  • Cooler Type RGB Accessories
  • Note Size of the ARGB devices that you are connecting should be within 12*6mm
  • Fan Safety Current 2.0 A (1 Port) / Total 4.5 A ( 6 Ports)
  • Series MasterFan
  • Series RGB Accessories
  • Weight 62g
  • Dimensions (L x W x H) 103 x 65 x 16 mm / 4.1 x 2.6 x 0.6 inch
  • Product Number MFX-ZHHN-1NNN6-R1
