MasterCase H500P Mesh image number 0
MasterCase H500P Mesh image number 1
MasterCase H500P Mesh image number 2
MasterCase H500P Mesh image number 3
MasterCase H500P Mesh image number 4
MasterCase H500P Mesh image number 5
MasterCase H500P Mesh image number 6
MasterCase H500P Mesh image number 7
MasterCase H500P Mesh image number 8
MasterCase H500P Mesh image number 9
MasterCase H500P Mesh image number 10
MasterCase H500P Mesh image number 11
MasterCase H500P Mesh image number 12
MasterCase H500P Mesh image number 13
MasterCase H500P Mesh image number 14
MasterCase H500P Mesh image number 15
MIND-BLOWING DESIGN
For a system being pushed to its limits, the H500P Mesh offers unrestricted airflow.
  • Series MasterCase Series
  • Materials - Body Steel
  • Materials - Outlook Steel Mesh
  • Liquid Cooling Support - Front 120mm
  • Liquid Cooling Support - Rear 120mm
  • Liquid Cooling Support - Rear 140mm
  • Legacy Cases
  • Liquid Cooling Support - Front 140mm
  • Fan Support - Front 2x 200mm Fan
  • Liquid Cooling Support - Top 120mm
  • 5.25" Drive Bays 0
  • Materials - Side Panel Steel
  • I/O Panel 2x USB 3.0
  • Size Mid Tower
  • Power Supply Support ATX
  • Liquid Cooling Support - Top 140mm
  • Materials - Outlook Plastic
  • Liquid Cooling Support - Front 240mm
  • Liquid Cooling Support - Front 280mm
  • Liquid Cooling Support - Top 240mm
  • Fan Support - Top 3x 120/140mm
  • Pre-installed Fans - Rear 1x 140 x 25mm Fan, 1200RPM
  • Liquid Cooling Support - Top 280mm
  • Expansion Slots 7+2
  • Liquid Cooling Support - Front 360mm
  • I/O Panel 2x USB 2.0
  • Motherboard Support E-ATX
  • Drive Bays - 2.5" SSD 2
  • Liquid Cooling Support - Top 360mm (maximum thickness clearance 55mm)
  • Motherboard Support ATX
  • Pre-installed Fans - Front 2x 200 x 25mm RGB Fan, 800RPM
  • Dimensions (L x W x H) 544 x 248 x 546mm / 21.4 x 9.8 x 21.5 inch
  • Dimensions (L x W x H) 544 x 242 x 542mm / 21.4 x 9.5 x 21.3 inch
  • Fan Support - Top 2x 200mm
  • Color(s) Gun Metal
  • Maximum Compatibility - CPU Cooler Height 190mm / 7.5 inch
  • Clearance - GFX 412mm/16.2"
  • Model Number MCM-H500P-MGNN-S10
