MasterBox TD500 image number 0
MasterBox TD500 image number 1
MasterBox TD500 image number 2
MasterBox TD500 image number 3
MasterBox TD500 image number 4
MasterBox TD500 image number 5
MasterBox TD500 image number 6
MasterBox TD500 image number 7
MasterBox TD500 image number 8
MasterBox TD500 image number 9
MasterBox TD500
MasterBox TD500
MasterBox TD500
MasterBox TD500
MasterBox TD500
MasterBox TD500
MasterBox TD500
MasterBox TD500
MasterBox TD500
MasterBox TD500
SHOW OFF YOUR STYLE
MasterBox TD500
MasterBox TD500
  • Materials Steel
  • Dust Filters Top
  • RGB Cable 1 to 5 Splitter Cable Included
  • Dust Filters Front
  • Materials Plastic
  • 3.5" Drive Bays 2
  • I/O Panel 2x USB 3.0
  • Color(s) Black
  • RGB Control RGB controller included
  • Legacy Cases
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Cable Routing - Behind Motherboard Tray 19mm / 0.74"
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • Expansion Slots 7
  • Motherboard Support ATX
  • Drive Bays - 2.5" SSD 4 (Max. 6)
  • Pre-installed Fans - Front 3x 120mm RGB Fan
  • Dimensions (L x W x H) 493 x 217 x 468 mm
  • Clearance - GFX 410mm/16.1"
  • EAN Code 4719512071106
  • UPC Code 884102043604
  • Model Number MCB-D500D-KANN-S00
