MasterBox MB530P Mid Tower Case image number 0
MasterBox MB530P Mid Tower Case image number 1
MasterBox MB530P Mid Tower Case image number 2
MasterBox MB530P Mid Tower Case image number 3
MasterBox MB530P Mid Tower Case image number 4
MasterBox MB530P Mid Tower Case image number 5
MasterBox MB530P Mid Tower Case image number 6
MasterBox MB530P Mid Tower Case image number 7
MasterBox MB530P Mid Tower Case image number 8
MasterBox MB530P Mid Tower Case image number 9
MasterBox MB530P Mid Tower Case image number 10
SHOWROOM READY.
The MasterBoxMB530P utilizes the aggressive intakes seen on the MB510L, MB511, and MB520, but employs glass on both of the side and the front panel.
  • Materials Steel
  • Dust Filters Top
  • Dust Filters Front
  • ARGB Cable 1 to 3 ARGB Splitter cable included
  • Materials Plastic
  • 3.5" Drive Bays 2
  • I/O Panel 2x USB 3.0
  • Color(s) Black
  • Series MasterBox Series
  • Size Mid Tower
  • Materials Tempered Glass
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Clearance - PSU 180mm/7.1"
  • I/O Panel 2x USB 2.0
  • Motherboard Support ATX
  • Expansion Slots 7
  • Fan Support - Top 2x 140mm
  • Fan Support - Top 3x 120mm
  • Cable Routing - Behind Motherboard Tray 18-25mm
  • Clearance - GFX 410mm/16.1"
  • Pre-installed Fans - Rear 1x 120mm Non-Led fan
  • 2.5" Drive Bays 4
  • Radiator Support - Top 360mm (44mm max motherboard component height)
  • Fan Support - Front 2x 140mm (can only mount behind the front plate)
  • Dimensions (L x W x H) 489 x 229 x 469mm
  • Model Number MCB-B530P-KHNN-S01
