MasterBox MB311L ARGB image number 0
MasterBox MB311L ARGB image number 1
MasterBox MB311L ARGB image number 2
MasterBox MB311L ARGB image number 3
MasterBox MB311L ARGB image number 4
MasterBox MB311L ARGB image number 5
MasterBox MB311L ARGB image number 6
MasterBox MB311L ARGB image number 7
MasterBox MB311L ARGB image number 8
MasterBox MB311L ARGB image number 9
MasterBox MB311L ARGB image number 10
MasterBox MB311L ARGB image number 11
Gear up, cool off
The MasterBox MB311L ARGB is a Micro-ATX airflow PC case pre-installed with two ARGB fans and made to be built with the latest gaming hardware.
  • Model Number MasterBox MB311L ARGB: MCB-B311L-KGNN-S01, MasterBox MB311L ARGB w/ controller: MCB-B311L-KGNN-S02
  • Exterior Color Black
  • Materials - Body Steel, Mesh, Plastic
  • Dimensions (L x W x H) 435.5 x 217.5 x 410mm (Incl. Protrusions), 366.5 x 210 x 400mm (Excl. Protrusions)
  • Volume 30.79L (excl. Protrusions)
  • Expansion Slots 4
  • 5.25" Drive Bays N/A
  • 3.5" Drive Bays 2
  • 2.5" Drive Bays 2
  • I/O Panel 1x 3.5mm Mic Jack
  • I/O Panel - Other 1x ARGB 2-to-3 Splitter
  • I/O Panel - Other MasterBox MB311L ARGB w/ controller: 1x ARGB Controller
  • Pre-installed Fans - Front 2x 120mm ARGB Fan
  • Fan Support - Front 3 x 120mm* / 2 x 140mm (*can only mount behind the front plate)
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 120 / 240mm
  • Radiator Support - Front 120 / 140 / 240 / 280mm
  • Clearance - CPU Cooler 166mm
  • Clearance - PSU 325mm (w/o front radiator & drive cage), 140mm (drive cage in backmost position)
  • Clearance - GFX 344mm
  • Cable Routing 18-22mm
  • Size Mini Tower
  • Series MasterBox Series
