MasterBox 520 MESH Blackout Edition image number 0
MasterBox 520 MESH Blackout Edition image number 1
MasterBox 520 MESH Blackout Edition image number 2
MasterBox 520 MESH Blackout Edition image number 3
MasterBox 520 MESH Blackout Edition image number 4
Embracing Darkness
MasterBox 520 Mesh Blackout Edition is the ideal chassis for both novice and experienced gamers alike, providing users multiple options in case design
  • Dust Filters Top
  • Materials - Exterior Steel
  • Dust Filters Front
  • Exterior Color Black
  • 3.5" Drive Bays 2
  • Series MasterBox Series
  • Size Mid Tower
  • Radiator Support - Top 360mm
  • Dust Filters Bottom
  • Motherboard Support SSI CEB
  • Power Supply Support ATX
  • Fan Support - Rear 1x 120mm
  • Radiator Support - Top 280mm
  • Materials - Exterior ABS Plastic
  • Materials - Exterior Tempered Glass
  • Motherboard Support E-ATX*
  • Clearance - PSU 200mm
  • Included Accessories 1 to 3 Fan Cable
  • Expansion Slots 7
  • Motherboard Support ATX
  • Fan Support - Top 2x 140mm
  • 2.5" Drive Bays 3
  • Fan Support - Top 3x 120mm
  • Motherboard Support (*up to 12" x 10.7" motherboards, may impact cable management feature)
  • Radiator Support - Top (recommended maximum thickness -55mm)
  • Clearance - GFX 410mm/16.1"
  • I/O Panel 1x 3.5mm Headset Jack (Audio+Mic)
  • Volume 43L
  • Pre-installed Fans - Rear 1x MasterFan Lite 120mm non-LED Fan
  • Clearance - PSU (Recommended up to 170mm)
  • Pre-installed Fans - Front 3x Sickle Flow PWM non-LED Fan
  • I/O Panel 1x USB 3.2 Gen 2 Type-C
  • I/O Panel 1x USB 3.2 Gen 1 Type-A
  • I/O Panel 1x Reset
  • Dimensions (L x W x H) 499 x 210 x 498mm (Incl. Protrusions)
  • Dimensions (L x W x H) 430 x 210 x 479mm (Body Size)
  • Model Number MB520-KGNN-SNO
