MasterBox 5 MSI Edition image number 0
MasterBox 5 MSI Edition image number 1
MasterBox 5 MSI Edition image number 2
MasterBox 5 MSI Edition image number 3
MasterBox 5 MSI Edition image number 4
MasterBox 5 MSI Edition image number 5
MasterBox 5 MSI Edition image number 6
MasterBox 5 MSI Edition image number 7
You Decide the Inside
  • Liquid Cooling Support - Rear 120mm
  • Legacy Cases
  • Series MasterBox Series
  • Size Mid Tower
  • I/O Panel 2x USB 3.0
  • Liquid Cooling Support - Front 240mm
  • Dust Filters Bottom
  • Power Supply Support ATX
  • Liquid Cooling Support - Front 280mm
  • Fan Support - Rear 1x 120mm
  • Clearance - PSU 180mm/7.1"
  • Drive Bays - SSD 1
  • Liquid Cooling Support - Front 360mm
  • Expansion Slots 7
  • Motherboard Support ATX
  • Materials Steel body
  • Cable Routing - Behind Motherboard Tray 25-35mm
  • Materials Plastic mesh bezel
  • Clearance - CPU Cooler 167mm/6.5"
  • Color(s) Black & Red with MSI logo
  • Clearance - GFX 410mm/16.1"
  • Dimensions (L x W x H) 500 x 220 x 475 mm
  • EAN Code 4719512058459
  • UPC Code 884102031250
  • Model Number MCX-B5S2-KWNN-03-MI
