MasterAir MA620P image number 0
MasterAir MA620P image number 1
MasterAir MA620P image number 2
MasterAir MA620P image number 3
MasterAir MA620P image number 4
MasterAir MA620P image number 5
MasterAir MA620P
MasterAir MA620P
MasterAir MA620P
MasterAir MA620P
MasterAir MA620P
MasterAir MA620P
Supercharged Cooling Performance
MasterAir MA620P
The MasterAir MA620P is built for extreme cooling performance. Based on the legendary Hyper 212 heatsink but with the twin tower design.
  • Heat Pipe Dimensions Ø6mm
  • Fan Speed 600-1800 RPM ± 10%
  • Cooler Type Air Cooler
  • LED RGB
  • CPU Socket LGA2066
  • CPU Socket LGA2011-v3
  • Product Number MAP-D6PN-218PC-R1
  • Heat Sink Dimensions (L x W x H) 116 x 110.1 x 165 mm / 4.6 x 4.3 x 6.5 inch
  • Heat Sink Weight 850g / 1.87lb
  • Fan Air Pressure 1.65 mmH2O ± 10%
  • Fan MTTF 160,000 Hours
  • Series MasterAir
  • Fan Safety Current 0.37A
  • Heatpipes 6
  • CPU Socket LGA1366
  • Heat Sink Material 6 Heat Pipes
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • CPU Socket AM4
  • CPU Socket AM3+
  • Heat Sink Material CDC 2.0
  • CPU Socket AM3
  • CPU Socket AM2+
  • CPU Socket AM2
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Fan Power Consumption 3.6W
  • Fan Rated Current 0.30A
  • Fan Airflow 53.4 CFM ± 10%
  • Fan Noise Level 31 dBA (Max)
