Hyper 212 LED image number 0
Hyper 212 LED image number 1
Hyper 212 LED image number 2
Hyper 212 LED image number 3
Hyper 212 LED image number 4
Hyper 212 LED
Hyper 212 LED
Hyper 212 LED
Hyper 212 LED
Hyper 212 LED
Hyper 212 LED
Hyper 212 LED is equipped with PWM Fan with red LEDs and provides the best airflow and static pressure to take the heat away.
  • Heat Pipe Dimensions Ø6mm
  • Cooler Type Air Cooler
  • CPU Socket LGA2066
  • Note *Due to mechanical limitations, AM4 upgrade kit is only supported by the Hyper 212 LED AM4 compatible version.
  • Heatpipes 4
  • CPU Socket LGA2011-v3
  • Fan Bearing Type LDB
  • Fan MTTF 280,000 Hours
  • Series Hyper
  • Heat Sink Material Copper (Heat Pipes)
  • Fan Speed 600-1600 RPM ± 10%
  • Fan Air Pressure 1.7 mmH2O ± 10%
  • CPU Socket LGA1366
  • Heat Sink Dimensions (L x W x H) 116 x 60 x 160 mm
  • CPU Socket LGA1200
  • CPU Socket LGA1156
  • Heat Sink Weight 468g
  • CPU Socket LGA1155
  • CPU Socket LGA1151
  • Dimensions (L x W x H) 120 x 84 x 160 mm
  • Fan Noise Level 9 - 31 dBA
  • CPU Socket LGA1150
  • CPU Socket LGA775
  • Product Number RR-212L-16PR-R1
  • CPU Socket AM4
  • CPU Socket AM3+
  • CPU Socket AM3
  • CPU Socket AM2+
  • Fan Power Consumption 2.28W
  • Fan Rated Current 0.19A
  • CPU Socket FM2+
  • CPU Socket FM2
  • CPU Socket FM1
  • Fan Dimensions (L x W x H) 120 x 120 x 25mm
  • Fan Weight 166g
  • Fan Airflow 66.3 CFM ± 10%
