Hyper 212 Halo White image number 0
Hyper 212 Halo White image number 1
Hyper 212 Halo White image number 2
Hyper 212 Halo White image number 3
Hyper 212 Halo White image number 4
Cooler Master is relaunching its most acclaimed air cooler with the new Hyper 212 Halo White.
Buy Now
BLACK ALUMINUM
TOP COVER
Clean modern design featuring matching aluminum top cover with signature logo
JET-BLACK HEAT PIPES
4 heat pipes with black finish provide exceptional cooling and aesthetics
Wide Range Compatibility
Compact 154mm height designed for wide chassis compatibility without sacrificing performance
UPGRADED INSTALLATION BRACKETS
Redesigned brackets simplify installation on the latest available platforms
  • Product Number RR-S4WW-20PA-R1
  • Exterior Color White
  • Dimensions (L x W x H) 124 x 73 x 154 mm / 4.8 x 2.8 x 6.0 inch
  • Heat Sink Material 4 Heat Pipes / Aluminum Fins
  • Fan Dimensions (L x W x H) 120 x 120 x 25mm
  • Fan Quantity 1 PC
  • Fan Speed 650-2050 RPM ± 10%
  • Fan Airflow 51.88 CFM (Max)
  • Fan Air Pressure 2.89 mmH₂O (Max)
  • Fan MTTF >160,000 Hours
  • Fan Noise Level 27 dBA (Max)
  • Fan Rated Current 0.28A
  • Fan Safety Current 0.54A
  • Fan Power Consumption 3.36W
  • Cooler Type Air Cooler
  • Series Hyper
  • Heatpipes 4
