Rediscover PC DIY: a form of entertainment, a polished skillset, an exquisite art form, and a way of living.
Created Only for the Best
HAF 700 EVO
The HAF 700 EVO truly has no limits as it is drawing inspiration from our ever-growing community of enthusiasts.
Hardware & Connectivity
No Limits
The HAF 700 EVO is capable of housing up to SSI-EEB motherboards (E-ATX), as well as any sized graphics cards in BOTH horizontal and vertical orientations.
HAF 700 EVO comes with dual exclusive 200mm SickleFlow PWM "Performance Edition" fans tailored to strike a balance between performance potential and noise levels.
MAMMOTH RADIATOR SUPPORT
INTEGRATED HUB
The unique removable top panel design allows you to effortlessly install, reach and maintain cooling components such as fans and radiators even in builds with complex custom cooling systems.
Rotatable Radiator Bracket
Two rotatable radiator/fan brackets included out of the box for showcasing cooling components at unique angles.
Iris: Customizable Lcd Assistant
Monitor system and game stats in real time or showcase your favorite video and images.
Better yet, customize and create a setup that is truly unique by connecting to MasterPlus+
ARGB Gen2 Ready, Controller Included
ARGB Gen2 technology allows users to explore full range customization down to the lighting effecting of each individual LED, while remaining compatible with third party devices.
Design
Edge Lit Intake Blades
Sleek, premium tempered glass or performant mesh? Why choose? Thick, robust ARGB tempered glass Intake Blades create unique, futuristic lighting effects while maintaining the thermal efficiency and performance of mesh that you love.
An included vertical graphics card holder with PCle 4.0 riser cable grant users the flexibility of choice in aesthetic display and airflow performance.
...Because what's the point of owning a flagship case without having
a bit of fun? The Infinity Mirror allows you to turn extra clearance in
the build into your personal Hall of Fame.
HAF 700 EVO's structure segregates non heat sensitive components so heat dissipation can be targeted towards heat sensitive components at an overall higher efficiency.
