FEEL THE CURVE
Get closer to the action with the 1500R VA panel. With a larger perceived field of view, you'll save on setup space, face less distortion and enjoy better eye comfort, in a truly immersive vantage point.
View your content with an entirely new level of immersion with our ultra-wide 34" curved monitor. With top-notch gaming specifications along with wide color gamut support, the GM34-CWQ ARGB monitor is the perfect centerpiece addition to your work and play setup.
With an enhanced VA panel technology, the possibility of light leakage across the entire screen is greatly minimized. The GM34-CWQ ARGB monitor is able to deliver a static 4000:1 contrast ratio for extremely deep black levels and brilliant whites in even the darkest and brightest scenes.
For productivity and content creation, the ultra-wide resolution of 3440x1440 offers vastly wider screen space for increased multi-tasking efficiency. Scrubbing timelines in Adobe Premiere or working through spreadsheets is easier when you have more screen real estate to work with. For gaming, the ultrawide panel puts you closer to the action and makes you feel more immersed within the game.
After activating HDR, you can choose from three HDR modes: Standard, Game, and Movie. Standard HDR mode allows you to adjust R/G/B color values, as well as brightness and contrast to better suit your preferences. Game and Movie HDR modes have preset configurations to optimize the HDR viewing experience based on your content.
With a 144Hz refresh rate combined with an ultra-fast 0.5ms (MPRT) response time, your games will look clearer than ever before. Track enemies with precision and dominate the battlefield as your enemies struggle to keep up with your speed.
With FreeSync Premium, gamers are ensured a fluid, tear-free gameplay experience that also supports low framerate compensation (LFC). No matter what the game is, you'll be able to enjoy impeccably smooth gameplay at an even larger framerate range.
Gain the competitive edge over your opponents with our Black Stabilization mode. In particularly dark areas within games, it can be very hard to see your enemies, leaving you vulnerable. Turning on Black Stabilization will allow you to see your opponents much more easily and allow you to get the jump on them.
Especially useful for night-time gaming sessions, the Low Blue Light Display reduces the amount of potentially harmful blue light and makes you feel at ease during long play sessions. Also helpful in reducing eye strain and overall allowing you to play or work even longer.
Using the MasterPlus+ app, you can fully customize the ARGB lighting built into the Halo stand. Set specific colors for certain occasions as well as synchronize lighting to your other compatible Cooler Master peripherals.
A single USB Type C port is built into the monitor, providing up to 65W PD power output which can fully charge your devices such as a laptop or other USB C compatible devices. It also supports signal display out via DisplayPort 1.4, so you can charge and connect your laptop or device to an external display all through one USB C cable only.
Whether you're at the office, or in your gaming cave, the GM34-CWQ ARGB has a clean design with minimal branding that can fit perfectly in any setup.
• Height: 0-80mm
• Swivel: -15°~+15°
• Tilt: -5°~+15°
Thick frames are so yesterday. Welcome our super narrow bezel design that tastefully complements your content without a distracting large black casing. See more of what matters and less of the things that don't.
Connect all your devices with the wide range of I/O ports consisting of:
• 1 x DisplayPort
• 2 x HDMI
• 1 x USB Type C (65W PD, DP1.4)
• 2 x USB Type A
• 2 x 5W built-in speakers
• 1 x 3.5mm headphone jack
