Elite Platinum 850-1300W image number 0
Elite Platinum 850-1300W image number 1
Elite Platinum 850-1300W image number 2
Elite Platinum 850-1300W image number 3
Elite Platinum 850-1300W image number 4
Elite Platinum 850-1300W image number 5
Elite Platinum 850-1300W image number 6
Elite Platinum 850-1300W image number 7
Elite Platinum 850-1300W image number 8
Elite Platinum 850-1300W image number 9
Elite Platinum 850-1300W image number 10
Elite Platinum 850-1300W image number 11
Elite Platinum 850-1300W image number 12
Elite Platinum 850-1300W image number 13
Elite Platinum 850-1300W image number 14
Elite Platinum 850-1300W image number 15
Platinum Efficiency, Robust Protection
• 80 PLUS Platinum – Up to 92% efficiency for lower power loss.
• ATX 3.1 & PCIe 5.1 Ready – Supports latest GPUs and power standards.
• Dual-Color 12V-2x6 Connector – Helps ensure proper cable connection.
• Smart Thermal Control – Zero RPM mode at low loads for quieter operation.
• 100% Japanese Capacitors – Premium components for long-term reliability.
ELITE PLATINUM POWER SUPPLY
Introducing the ELITE PLATINUM 850~1300 ATX 3.1 PSU with PCIe 5.1 support. Designed for modern DIY builds, it delivers high-efficiency power with enhanced durability and long-term reliability.​
Built with 100% Japanese capacitors, protective PCB coating, and a compact 140mm form factor, the fully modular Elite PLATINUM 1000 offers stable performance and a 12-year warranty for dependable everyday use.
A LONG-TERM CHOICE FOR PEACE OF MIND
80 PLUS PLATINUM CERTIFICATION
Efficiency exceeds 92% under typical load at 115V, which can reduce power loss and optimize thermal performance.
ATX 3.1 PCIe 5.1
Complies with the ATX 3.1 standard, capable of withstanding 200% peak power excursions, ensuring stable compatibility with next-generation graphics cards. Equipped with a dual-color 12V-2x6 connector, it utilizes a two-color indicator cable design to easily confirm a secure connection, reducing the risk of poor contact.
NATIVE PCIe 5.1
Supports 50-series high-end graphics cards, while being backward compatible with other graphics cards, satisfying a wider range of PC building needs.
NATIVE PCIe 5.1
EXCELLENT COOLING: BOTH EFFICIENT AND STABLE
Utilizing a rifle bearing fan, the cooling is stable and reliable, extending the service life. Equipped with a smart temperature control mode, the fan stops spinning (zero RPM) under low loads to achieve silent operation; it automatically starts up at approximately 40% load, balancing both cooling and stability.
100% JAPANESE CAPACITORS, PREMIUM COMPONENTS
Uses 105°C high-temperature resistant, high-quality Japanese capacitors to enhance precision, reliability, and long-term durability.
ELITE FAMILY EXTERIOR DESIGN
Inherits the classic honeycomb mesh exterior design of the Elite series, effectively improving cooling performance.
FULL CONFORMAL COATING COVERAGE
Moisture-proof, dust-proof, and corrosion-resistant, effectively extending product lifespan.
140MM SHORT CHASSIS
Dimensions: 140 × 150 × 86 mm, a shorter chassis offers higher case compatibility.
12-YEAR WARRANTY
This equipment comes with a 12-year limited manufacturer's warranty from the date of purchase, ensuring greater peace of mind for long-term use.
COMPREHENSIVE PROTECTION, SAFE AND STABLE
6-Tier Protection Mechanism: OVP / OPP / SCP / OCP / UVP / OTP
EU RoHS ENVIRONMENTAL CERTIFCATION
True long-termism. The entire series utilizes a lead-free, eco-friendly manufacturing process that complies with the EU RoHS directive. Even under high-load heating conditions, there is no risk of heavy metal volatilization, creating a truly clean and safe breathing environment.
