New
Elite Gold 1200 (All-Japanese Capacitors)
Supports ATX 3.1 and PCIe Gen 5.1 standards
Ideal for RTX 50 GPUs
Stable performance under high loads at up to 40°C
Quiet, long-life Rifle Bearing Fan cooling
1200W output with 80 Plus Gold-certified efficiency
Fully modular embossed cable design
Reliable 10-year warranty
HIGH-POWER GOLD PERFORMANCE FOR GAMING AND WORKSTATIONS
Cooler Master Elite Gold 1200 (All-Japanese Capacitors) powers high-end gaming rigs and professional systems with ATX 3.1 support - ideal for RTX 50 GPUs. It offers 80 Plus Gold efficiency, reliable operation up to 40°C, quiet FDB cooling, embossed modular cables, dual EPS connectors, and a 10-year warranty for dependable, high-load performance.
High Temperature Resilience
Operates reliably at up to 40°C, making it ideal for extended gaming sessions, professional rendering, and sustained high-load workloads—all without sacrificing stability or efficiency.
Compatible with ATX 3.1 and PCIe Gen 5.1 standards
ATX 3.1 provides tighter voltage and current regulation, supporting up to 200% peak power. The Elite Gold 1200 meets full ATX 3.1 specs and supports PCIe Gen 5.1 for stable next-gen performance with RTX 50 GPUs and future high-power cards.
RIFLE BEARING FAN
Cooler Master Elite Gold 1200 achieves over 90% efficiency at typical loads, reducing energy waste and heat output.
The fully modular design comes with flat black cables that can be tailored to each build, offering improved grip and a premium look for easier management and a cleaner overall setup.
PSU CALCULATOR
